1999 c70 is it a bad tranny or bad sensor(s)
Old 03-24-2011 | 09:17 PM
carolina, PR's Avatar
Default 1999 c70 is it a bad tranny or bad sensor(s)
Driving my 1999 c70 one day out of the blue, the trans stopped working, I pulled over turned the car off, started it and the tranny worked fine for the next 2 weeks, then the tranny went out again, turned the car off, started it up again and went home. The following morning went to a tranmission place and they told me I neede to rebuild my tranny. This thing with my tranny has beeb going on now for a month and half, the car still runs, but affraid it might leave me out in the middle of nowhere. My check engine light came on, is this the sign that I have a bad tranny or mabey one or two bad sensors? Doing some reaserch I found out this car is equipped with with a speed sensor and a tcm sensor. If one of these sensors go bad, does it make the tranny have these issues or again am I looking at rebuilding my tranny?
Old 03-24-2011 | 10:24 PM
The signs of a transmission going bad usually starts with slipping. From there a gear goes out, like reverse or it doesn't like to shift out of 1st, something like that. If it just quit, it is likely an electrical problem, computer problem, or something like that.
Old 03-25-2011 | 09:35 AM
Thank that makes a lot of sence, but at the same time does anyone have a lil bit more explanation as to why?
Old 03-25-2011 | 06:25 PM
MattyXXL's Avatar
What is the code?
Old 03-26-2011 | 08:49 AM
I will know this monday afternoon what the code is. This is very strange, I was driving the car all day yesterday and planning an using it today. When I schedualed the appointment and spoke to the owner of "situation volvo" one of the first things that came out of his mouth after answering my question was, "it seems like you need a new tranny" and the dude watched me drive away in my volvo c70, do you think this guy know anything about trannys, volvos?
Old 04-19-2011 | 11:21 PM
bimmerd00d's Avatar
I had a VSS (vehicle speed sensor) go out and it caused the transmission to go into limp home mode briefly. I'd reset the computer and then it would slam itself between gears if you gave it more than like 2% throttle. Found a post on here where a guy had the same issue. Replaced both VSS' since i couldn't figure out which was which. All has been well for about 2yrs.
Old 04-20-2011 | 05:07 AM
BPATR1CK's Avatar
Code will tell. You should have TWO speed sensors, one on each rear wheel...You sure it's not just the shifter, or an engine issue??
Old 04-20-2011 | 05:08 AM
BPATR1CK's Avatar
The other to consider would be the trans. "Range" sensor I assume...
Old 04-20-2011 | 04:26 PM
bimmerd00d's Avatar
No, the sensors i am talking about are on the Transmission, underneath the air filter box.
Click this thread, and you'll see what fixed mine.
https://volvoforums.com/forum/volvo-...8-18360/page2/
Old 06-09-2011 | 12:41 AM
DriveVolvo's Avatar
Default Check the ABS sensor!
My car acted like there was a problem with the transmission. My mechanic changed out the Speed sensor. Problem continued Ended up taking it to the Volvo dealership 2 hours away and they said it was the ABS sensor...hmmm....could that be why the ABS and check engine lights had been on for ages? It seemed to be the answer. The car has run like a dream ever since. Hope this helps you.
Old 10-17-2011 | 06:14 PM
blaine's Avatar
i have a 92 an i changed the rear seal in th motor an now the trans want shift till 3500rpms an i have to do it manuly ,, an the motor has a bad miss like its jumped time ,,, but i did nothing but change th back seal ? so can some 1 help me with this problem please ty
Block91
2001-2013 model year V70
23
04-03-2020 10:53 PM
securisign
05-31-2014 12:10 PM
raged
06-09-2012 12:08 AM
trussguy
01-25-2009 07:07 PM
swede850T
06-13-2005 03:12 PM
