2000 c70 convertsble top help!
Hi I have a problem with my soft top it would not do anything when I hit the button but the button blinks orange and makes a chime also I found there is a these codes and want to know if its one thing causing all these codes to come on thank you...
-CAB-120
-CAB-212
-CAB-213
-CAB-214
-CAB-221
-CAB-120
-CAB-212
-CAB-213
-CAB-214
-CAB-221
just pulled off the carpet cover on the trunk lid and put some dielectric grease on it and the problem was gone.
the dielectric grease is like $14 a permatex size tube but in my opionion it is 1 of the best investments you can make on any electrical connection on auto and anything with a motor period. and that tube last a long time.
try putting some on your trunk connection and smearing it on your e-brake connection under the panel in the console and see if that fixes your problem.
if not its likely the trunk sensor needs replacing since the top will not move if it thinks the trunk is open. the e-brake is a simple slide connection so it is less likely the problem in my opinion
jh23job
Feb 15, 2011 11:44 AM
pacificnw2011
Sep 5, 2010 07:42 PM
