2004 C70 brake discs and grinding
New to me C70, stops fine, brake pads all look good without any uneven wear. However there is periodic low speed grinding while braking. I noticed that the discs are machined such that the braking surface is in a trough relative to a ridge on the outside diameter. Is this the normal configuration? I've not seen this before.
