2004 c70 misfire problem and fix
Old Jan 28, 2013 | 05:11 PM
trashcanman's Avatar
Default 2004 c70 misfire problem and fix
I recently purchased a 2004 c70 with 89k miles. After a week of driving my girl alerts me to a check engine light and extremely rough idle at stop and at all speeds. Parts store code reader pointed to cylinder 3 misfire. Replacement of said plug and coil pack produced immediate positive results. I see alot of people posting questions and problems but sadly not many post back about the fix. Since repair manuals are basically nonexistent i thought this may at least spread some knowledge
Old Jan 30, 2013 | 03:39 AM
MSGTUSMC's Avatar
Remember all the plugs & the coil paks are the same age, probably. Fuel economy & performance might be improved by replacing them all!
Old Jan 30, 2013 | 03:27 PM
Agreed. While i was in there i noticed that one had already been replaced. So yes 3 are still factory. Also the one plug from #3 has a short, needle like tip. Is this the way some plugs are made? Or was the tip likely burnt out?
Old Jan 31, 2013 | 05:04 AM
MSGTUSMC's Avatar
Probably a high arc burnt tip.
Old Jan 31, 2013 | 11:21 AM
Thanks for your replies master sarge. Once it warms here in the south im gonna go over this car with a fine tooth comb and get everything right...rest of the plugs, coil paks, heater core and antenna issue
Old Mar 9, 2014 | 11:02 PM
bryants40's Avatar
I have a 2001 S40. I have replace wires, plugs, and a bad coil in #3.
I have a rough idle and it has codes for misfire in 3 and 4. p0303, p0304. Any suggestions?
Old Mar 11, 2014 | 03:15 AM
MSGTUSMC's Avatar
Did you replace the COP & plug for #3 & #4 cylinder?
Old Mar 11, 2014 | 04:11 AM
It is likely a iridium plug.
Old Mar 11, 2014 | 06:13 PM
quietlymknnoise's Avatar
Volvo OEM plugs have the same tip.
drenman
Nov 29, 2016 07:35 AM
theotherpilot
Jul 10, 2009 12:28 AM
Volvorator
Mar 15, 2007 10:37 AM
