2006 C70 T5 Cabn Filter
Old Oct 28, 2008 | 07:42 PM
drwillis's Avatar
Default 2006 C70 T5 Cabn Filter
We just bought a 2006 C70 T5, Where is the Cabin Filter and how I change it?
Old Nov 9, 2008 | 07:57 PM
Pearsonmx6's Avatar
Default RE: 2006 C70 T5 Cabn Filter
you need to remove the gas pedal there are 3 10mm screws holding it on then there are 3 7mm screws holding the filter cover on. it is on the right side of the pedal.
Old Nov 10, 2008 | 06:20 PM
PANTYEATR's Avatar
damn! thats retarded! why would volvo put it there? what if you strip the bolt holes out? i would convery that gas pedal bolts to studs just for that.
Old Nov 11, 2008 | 06:47 PM
Pearsonmx6's Avatar
the c70 v50 c30 and new s40 are all on the same platform and are called P1 cars. ford wanted to put a 4 cyl engine in there but volvo said no. so the normal design air box would not work. they had to use one off of some other car and they picked one from a righthand drive car. thus the crappy design.
I work at a volvo dealership and do 3-4 a week and they really do suck. the gas pedal is held on by studs and sometimes the weld on the back of the stud brakes and you need to pull out the brake pedal to get the gas pedal out.
Old Nov 16, 2008 | 04:30 PM
drwillis's Avatar
Wow, Thanks, I'm heading in, I'll let you what I find
surfbros
Sep 16, 2013 04:07 PM
edahlgren
Oct 21, 2010 06:24 PM
znguy
Oct 8, 2009 10:19 AM
Bruce Brown
Mar 9, 2008 02:27 PM
ohskigod
Aug 31, 2006 12:22 PM
