Battery Help !
Old Oct 14, 2008 | 11:08 AM
Wiretrvler's Avatar
Default Battery Help !
Hey guys, and or ladies
I'm buying an after market Bosch battery for my 2002 C70, the stock battery seems to slide into the battery bracket, do I need to buy new brackets etc. ?
Thanks
Old Oct 14, 2008 | 11:17 AM
TIPSP's Avatar
Got Boost?
Default RE: Battery Help !
Do you mean that the battery slides aroundin the bracket? If yes, then I would look at replacing it, or Fixing it.
Old Oct 14, 2008 | 11:25 AM
You need a 47 series battery. There is a clip that locks onto the edge of the battery tray that holds the battery still.
Old Oct 14, 2008 | 11:27 AM
Wiretrvler's Avatar
It doesn't slide, it has the original battery and bracket and sits tight. The problem I see is the original battery $350.00 has some sort of hard plastic ***** on the bottom and you set them in slots located on the original bracket and pull the battery to the side, this locks the battery into the bracket. A small hard plastics clamp then clamps the battery from the bottom flanges to the bracket also. I'm afraid the new Bosch won't have the bottom ***** or flanges. Hard to discribe?
Old Oct 14, 2008 | 11:29 AM
Wiretrvler's Avatar
Thanks Tech, thats what I was trying to describe.
Old Oct 14, 2008 | 11:50 AM
Most batteries should have those lips so to say on the bottom of the battery.
Jeffers
Nov 21, 2012 06:50 PM
mrcanon918
Sep 24, 2009 12:35 PM
cmercon
Feb 2, 2009 02:15 AM
MarkS90Atlanta
Jun 19, 2008 05:38 PM
shavalena
Feb 24, 2008 11:39 AM
