Boost gauge hook up
ORIGINAL: dlehnhoff
Which of the lines- white, red or yellow, do I tap into to install the boost gauge?
Dwight
Dwight
Are you talking vaccum lines or power lines?
If this is a 1998 c70. You should have a vaccum tree located where your throttle body is. If you take that throttle body cover off you will see the vaccum tree. There should be some unused ports just run the line to one of these ports.
J. H. McCharen
May 26, 2014 11:26 AM
