another gauge question - boost gauge
Old May 25, 2011 | 01:06 AM
ibified's Avatar
Default another gauge question - boost gauge
ALso installing a boost gauge this weekend - need to know what the best way to tap into the hoses to get good read on the gauge. I know I could tee off of the boost gauge on the back of the dash with no problem, but is it better to run a separate line off from somewhere else? I dont need to do it the easy way, i need to do it the RIGHT way. Thanks in advance.
Old May 25, 2011 | 08:53 AM
Mad Matt's Avatar
The best way is to attach your Pressure line to the vacuum tree right next to the throttle body.
Old May 25, 2011 | 11:20 AM
ibified's Avatar
cool, thanks Matt. Whats the best way to route the vacuum line through the firewall?
Old May 25, 2011 | 12:37 PM
MattyXXL's Avatar
there is a firewall pass thru on both sides of the car... I cant find the one on the drivers side I think its below the pass thru for the other wires behind the abs set-up... but it will look like this...
This is the one on passenger side...
Its behind the strut housing..
Old May 25, 2011 | 02:23 PM
boxpin's Avatar
Why dont you disconnect the existing gauge and connect to the line already in the car? Do you need both gauges?
Old May 25, 2011 | 03:15 PM
ibified's Avatar
Boxpin: i was concerned about the condition of the factory vacuum line - i mean, it's 17+ years old and i was thinking that it might save me issues down the road to have new line run to the gauge to make sure it's reading accurately. Am I wrong in thinking this? If so, I would have no issue doing it that way - it would save a lot of time for me.
Old May 25, 2011 | 05:23 PM
Mad Matt's Avatar
That's what I did. So much easier then running the vacuum line through the firewall.
Old May 26, 2011 | 01:03 AM
91shelby's Avatar
I teed off the boost guage line in the engine bay then ran a new line thru the firewall on the drivers side and worked great
jhabeeb8
Feb 5, 2014 02:14 PM
559s40
Jul 13, 2012 10:50 PM
turbo940v
Sep 3, 2010 08:36 AM
endneu913
Mar 28, 2010 11:41 PM
