BRake Control Module Remival
The brake control module on my C 70 is right up against the firewall in the back behind the battery of the car. Has anybody had experience removing this from the car? I have had it to a few mechanics I can’t figure out how to get it off of the car!
Originally Posted by Mark Pedersen
(Post 506413)
The brake control module on my C 70 is right up against the firewall. can’t figure out how to get it off of the car!
https://cimg6.ibsrv.net/gimg/volvofo...863abbb1f6.jpg |
Wow! You are Awesome!!
I have been looking for this diagram everywhere else and could not.
thank you soooo much!!!! |
The car is a 2008 model with 73,000 miles on it.
I get fault codes CEM-E000 communication with control module faulty, BCM-0148 Communication between control units wrong configuration ID, EPS-0080 Steering angle sensor faulty signal. They all point to the Brake Control model or the wiring to it. Any other ideas? |
Is there a bolt that holds or connects the unit on the back firewall?
I have checked all of the fuses, the wiring, the connections and have found no problems. |
(Post 506426)
1. CEM-E000 communication with control module faulty, 2. BCM-0148 Communication between control units wrong configuration ID, 3. EPS-0080 Steering angle sensor faulty signal. . Any other ideas? 1. cem - e000 https://cimg7.ibsrv.net/gimg/volvofo...86d1dc0abb.jpg 2. bcm 0148 https://cimg7.ibsrv.net/gimg/volvofo...2c1e2a2315.jpg 3. eps 0080 https://cimg0.ibsrv.net/gimg/volvofo...653bdf443f.jpg |
Here is the latest
I scan the car with the Carly scrambler and get this;
https://cimg4.ibsrv.net/gimg/volvofo...df334032b.jpeg This messsge goes off after 20 seconds https://cimg6.ibsrv.net/gimg/volvofo...c5d5a02942.png After it runs a while I get the next pic after I turn the car off and then restart…I have no warning lights. ideas? |
More pics
https://cimg8.ibsrv.net/gimg/volvofo...3c37c907b.jpeg
This is the message I get after brake message goes off. |
