Brake Pedal goes WAY down...?
Hey Guys,
This is my first post. I actually just bought my son a 2004 C70 HPT Convertible.
I noticed during the test drive, that the brake pedal goes WAY lower than I expected...almost to the floor. Is there a way to have that adjusted or is that a problem I need to have looked at?
Thanks,
Thanks,
Several things can be causing this problem. 1 Low brake fluid, I would check all 4 caliphers for a leak. 2. Air in brake system, fill brake fluid at master cylinder and bleed all 4 wheels according to OEM instructions. 3. Bad master cylinder, rebuild or replace. 4. Bad brake line, replace. Good luck.
jpravi8tor
Aug 28, 2017 05:35 PM
Doormat
Mar 28, 2012 10:03 PM
