-   Volvo C70 (https://volvoforums.com/forum/volvo-c70-14/)
-   -   C70 door unlocks and opens itself while driving. (https://volvoforums.com/forum/volvo-c70-14/c70-door-unlocks-opens-itself-while-driving-83545/)
ward.bruce May 12, 2019 04:57 PM
yes, i really enjoy the car. I will find out what the dealer says and post it. I think I am out of the warranty though. I need to check, I am under 100k, but the over the years on the extended warranty. I have owned a Volvo consistently for 20+ years so I hope they own up to it.
ncarnall May 13, 2019 01:00 PM
Originally Posted by mamabear96 (Post 410115)
Hi, has anyone with C70 (2013) ever have this problem? I was driving long distance this weekend, about 4 hours, my car doors unlocked and door was ajar while I was driving. It happened 4 times. I had to pull over and close and lock the doors again and again. It didn't do that when I drove home with the top up. It only did that when the top was down. I'm baffled and frustrated. Any idea?
If it was serviced by volvo they are supposed to grease these with White grease. Volvo service tick the box but don’t always do it! I now service myself and I grease these with white grease. Then open and shut doors 10 or so times. If I forget, the doors start doing this just after each year. So if done at service you should not notice this happening. But if it does it hasn’t been serviced properly! Make you wonder what else they forget but tick.
APB053 May 14, 2019 02:36 PM
I had the problem with the door opening on its own about a year ago. It happened about four times in a two week period. I checked out this thread then, and noted what people have done about it. The consensus was it was a lubrication problem. Well, I'm a procrastinator and I never lubricated it. As a matter of fact I haven't done anythiing to try to correct the problem. It hasn't opened on its own in over a year. This leads me to believe that my car has learned to repair itself or lubrication is not the issue. Can't explain this one. Any ideas? Also it didn't matter if the top was up or down when the door opened on its own.. I have an 09 C70.
crease24 Jun 2, 2019 06:42 AM
Vovlo C70 doors opening
Purchased a previously owned 2013 C70 last year and immediately began having similar issues as others have described. Door lights come on and "Door ajar" notice initiated when driving at highway speeds with top down. This is quite unnerving, as I have to stop the vehicle and re-shut the doors. Have tried lubrication suggestion, but it has proved ineffective. I am a long time Volvo owner and am completely dismayed by the lack of culpability of Volvo and their dealers to effectively address this issue. If it is a defective electrical or latch issue, Volvo should have sent recall info out and the dealers should fix the issue. I have posted a complaint with the NHTSA.
APB053 Jun 2, 2019 11:35 AM
An update since my last post. The door stopped unlocking and opening on its own right after I replaced the battery in the 09 c70. It makes sense that it could be a software issue. When I replaced the battery everything had to reboot. This is just a theory, but I find it odd that once the battery was replaced I ceased to have the problem with the door opening. It has been over a year now, with no problems. Hope this helps.
crease24 Jun 2, 2019 12:59 PM
doors opening
Thanks for the info; hadn't considered the battery aspect. Will look into that option.
crease24 Jun 3, 2019 03:22 PM
Received a call from NHTSA investigator regarding C70 automatic door ajar notice while top down. Although genuinely interested, he could not say there was any one fix for the problem, but stated they do have an open investigation into this specific issue and suggested I contact VOLVO of AMERICA, which I did.
Unsurprisingly, Volvo of America has no open recalls for this problem. Their recommendation was to contact my Volvo Dealership and have them look into it.
So, I did call both Volvo dealers in Minneapolis/St. Paul area; was informed that if my vehicle needed a "latch" replacement, the cost would be upwards of $700 per door. Don't think he appreciated me laughing out loud at him. Will consider other remedies before taking the more expensive route.
TACanada Jun 27, 2019 01:14 PM
Just chiming in here again. Had my battery replaced by Volvo in the US about 2 years ago ($260+) and curiously enough compared to the comment above we never had this issue until the battery was replaced! So shows at best this is a complicated issue that Volvo could give a rat's a** about.
Just had this happen again about 3 weeks ago driving at highway speed with the top down.
Never had this issue with my '09 C70, which also had the battery replaced. That's another issue altogether as most know!
crease24 Jul 1, 2019 05:41 AM
I agree with your comment that it is a complicated issue that Volvo must certainly be aware of but feigns ignorance. Had another episode of the door opening yesterday while driving (with the top down) at less than 20 m.p.h. over a somewhat bumpy road. To say the least it's unnerving and truly an unsafe situation. Having applied numerous suggested remedies to no avail, I'm left wondering if selling the vehicle is my only option. Unfortunately that just transfers the problem to another owner. Volvo's lack of culpability saddens me. For a company that stresses safety, this is downright criminal. I've owned 4 Volvo's over the last 15 years; I may never buy another.......
bill1967t Jul 6, 2019 12:40 AM
C70 door unlock issue
Hi, just purchased a 2009 2l diesel SE C70 and the drivers door came unlocked 3 times during a 75 mile drive. Will try the grease but if no resolution will be taking it back to the dealer. The biggest problem will be convincing the dealer that the problem exists as there are no specific actions that cause it.
Update, sprayed the locks with white grease and so far the issue has gone
Chris_Lincs Aug 20, 2019 03:27 PM
I have had a replacement battery but the problem still exists. I have been into a local dealer today who suggested there is a fix and it does involve replacing or adjusting the Latches. I have emailed Volvo UK with this information requesting a response and a way forward. We'll see......
TACanada Nov 8, 2019 07:10 PM
Update: Slathered white lithium grease on both door latches (driver & passenger) and haven't had the problem since! Did a good road trip too (>2000 km) in late September, most at highway speeds and never had the problem.
Joe7Brothers Nov 9, 2019 08:54 AM
Before you go greasing the latches up, spray them heavily with brake cleaner. My sense of this is the original lubricant has dried up, and may cause the latch to not fully engage. Did mine 2 years ago, haven't had a problem since
TACanada Nov 9, 2019 01:36 PM
That's a good upgrade. All I did was wipe my latches clean but didn't use any cleaner. Thanks.
Chris_Lincs Nov 14, 2019 09:50 AM
Volvo resolved it for me
I followed this up with Volvo UK following my visit to the local dealer and initially they suggested they didn't know about the issue. I shared this forum with them. They then offered to get my local dealer to contact me - hmmm a circular conversation moment. Anyway, the dealer contacted me, booked me in and then between Volvo UK and the dealer, they fixed the problem by replacing the latches - f.o.c. A pleasing result as most of us who drive this car - we love them.
stevesecor Mar 30, 2021 09:07 PM
Hello fellow C70 lovers. I have a 2011 C70 and had the same issue with the (driver) door popping open at highway speeds - top up, top down, it didn't matter. Anyway, I had a feeling that maybe it had something to do with the auto lock system?!?!? So, I turned off the auto locks. Great, the door no longer opens while driving on the highway. In fact, now it no longer will open from the inside at all. I took the door panel off and found the cable was attached and working perfectly...so after reading all of your comments, I am hoping that it will be fixed by replacing the latch inside the door. Had the car at my trusty Volvo guy today for oil change and all that stuff and obviously he didn't have the part in stock so I think I am going to try this myself! I'm convinced after seeing your problems that the latch just has gone bad because I'm fairly sure that it was only a intermittent problem originally - yes, yes, I'm blaming myself for not fixing it then! Anyway, thanks you all for your time to post - it really is helpful to read similar stories
Djeader Apr 1, 2021 03:19 AM
I also don't like it. I think there is a problem with this type of Volvo
Darylwhitaker Oct 17, 2021 09:41 PM
C70 door comes open
[QUOTE=rharnettc70;449301]The same thing just happened to me 2x yesterday while drive on the highway with the roof down, frightened to death going 65 mph and your door goes ajar. Has anyone gotten Volvo to own up to the issue, clearly it's a problem - I am bringing my car in to the dealer tomorrow and I suspect to get the run around, anyone one with any confirmation that this is some sort of recall would be GREATLY appreciated![/QUOTE
If you took it to the dealer, what did they do to fix it
C70 door comes open
Alf 7633 Jun 29, 2022 10:25 AM
C70 door - Hum and Haw and time wasted
It had taken me months to try and solve my C70 2009 driver's door unlocking. On each occasion I tried to solve the problem myself by using the techniques helpfully explained in this forum but ultimately it came down to my taking the car to a Volvo dealership and they have fixed the problem by replacing the driver's side door lock. Total cost £358. However, it has been interesting and enjoyable to say the least to have followed the forum suggestions. Thank you All.
