C70 RHD Leak into drivers footwell
Old May 13, 2021 | 04:29 AM
JohnC70's Avatar
Default C70 RHD Leak into drivers footwell
Hi folks,
I've recently acquired a 2002 RHD C70 hardtop (NO SUNROOF) which has had an ongoing issue with a leak into the drivers footwell.
I've removed all the cowling in the bulkhead to check drains are free and working on. All appears fine. Tested it with a garden hose and again, no issues.
Looking under the dash a small weep is making it's way down from above where the wiring loom from the drivers door enters the A pillar. I can see a drop landing on top of the loom underneath the dashboard but can't see where it comes from.
This small weep, or drop, appears to only appear if I turn the hose on the windscreen where it is bonded to the A pillar.
Just to add, the seals on the drivers door appear find and the leak is appearing even with the door open and the hose running.
Can anyone help and give me direction where to look next.
EDIT: I've been doing a little bit more checking as the car had dried out, it appears the leak is starting at the top of the A pillar where it joins the roof and is working it's way down the A pillar and then down into the dash board and out on to the carpets. Is this possible?
Old Oct 17, 2021 | 01:59 AM
FrankGuthrie's Avatar
Volvo roof drain permanent fix.
Order the item below.
Remove pillar cover - remove stupid rubber drain tip (water may be trapped in drain tube - clean out tube in some way).
Install the silicone item - it's a perfect fit on drain tube and drain hole where rubber tip was. Replace pillar cover - done.
Never again - and a fraction of the cost of the original piece.
https://www.aliexpress.com/item/4000...e52e080e3518-9
There are plenty of other sources - prices vary quite a bit.
volvo taff
Oct 19, 2019 11:40 PM
Dingley00
Dec 18, 2010 04:53 AM
SnowSled
Apr 28, 2010 06:16 PM
C70CoupeMaui
Feb 25, 2008 09:38 AM
RipCity Euros
Jan 9, 2008 03:13 PM
