C70 won't start
I'm having a problem with my 2000 Volvo C70. The key won't turn to the start position. The remote lock/unlock had gotten smashed, so we were using the metal "service key". No problem for 2 days....then, my partner parked nose up on a hill, (rare here in Key West), and then the problem began. Taped up the remote and installed a new battery, looks ugly but works. Remote unlocks all doors, service key goes in ingnition and turns 1 click, panel lights, AC, etc come on... but I can't physically turn the key to "2" or "3" position. Could it be that parking on a hill (and maybe rolling a little bit in park) has confused the "start/neutral" switch? Thinking of rolling back to level ground and fooling with gearshift..... HELP!!! Volvo wants to tow it 160 miles to mainland, and then make me come and get it back!!!!!!!! Gina Maseratti.
RE: C70 won't start
Does the steering wheel unlock?
Are you 100% sure the keys are the same? |
RE: C70 won't start
Yes, steering wheel turns freely, it's the only key we have...it and remote work on doors, trunk, etc. Shift lock override works when key is in and turned to first stop, but key won't physically go to next posistion. Steering column/ ignition box seems a little loose. Wondering if someone tampered with it, but this car was fine 20 minutes before......
RE: C70 won't start
Possible the ignition switch is bad(Lock cylinder assembly)
If you need to know how to try to start let me know and I will PM you the info. Is the only other key you have also a computer key? |
RE: C70 won't start
I only have the one key and the remote unlock fob. Got the car on level ground, tried everything, still no go. Do I have to go to Volvo to re-program???? Thank you, Gina. maseratti@bellsouth.net
RE: C70 won't start
E-mail sent.
RE: C70 won't start
Yeah!!!!! It started! Thank you so much!!!! Now, i have to figure out why the key won't turn. Could this be the park/neutral switch?????
RE: C70 won't start
No it must be in the Lock cylinder assembly.
You will have to replace it. |
RE: C70 won't start
Where can I purchase the lock cylinder assembly???? Is it expensive???
RE: C70 won't start
I believe only the Dealer they will have to order it keyed to your car. This way you still won't have to have them program your keys.
It will take about 5 days for them to get it in. |
RE: C70 won't start
Did you ever get your car fixed? I have a 2001 Volvo C70 and mine stopped working as well. I had issues with it not starting up all the time, but since it didn't happen ALL the time, I pretty much ignored it..., until one day it just wouldn't start AT ALL, unless I got a jump. Although I got a jump, I knew I had something else going on since I was told by the dealer that I needed to change my positive wire sooner or later. Well I jumped the car and drove down to Volvo. I had a few things going on that caused my problem. #1 - was that my positive wire to the battery was corroided, so I had to get another one. #2 - battery cable to relay box was BURNT and since this was going on, it drained my car battery so I had to get another battery as well as another battery cable to the relay box. #3 - the contacts on my immoblizer harness had to be soldered and retensioned. After that was done, by car started up fine. They did check the antenna ring and that was fine, but I expected that to be since I had it replaced about 1.5 years ago. To fix my problem came up to $817.36. [:@] $613.90 was LABOR!!!! [:'(]
RE: C70 won't start
Hi,
We have a similar problem with a 2001 C70 where we can't go past position one. All fuses look good but I was curious what you did to start your car without turning the key past position one? Thanks, Chuck |
RE: C70 won't start
If it won't go past position 1 then the lock cylinder is bad.
Does the steering wheel unlock? If so PM me and I will give you info on how to get the car started. |
RE: C70 won't start
Gina Maseratti here. After 1 year of starting the C70 with a screwdriver, I put it all back together and it works fine!!!!!!! Hmmm.......
By the way, I'm running as a write in candidate for Presiden under the D.R.A.G. party (Drastic Reform of American Government) go to gina4president.blogspot.com |
HI,
My 2002 volvo c70 wont turn past position one either, and it never had problems starting in the past. i was driving a couple housr previous and no warning lights were on? |
ignition lock assembly
Originally Posted by tech
(Post 40400)
E-mail sent.
Originally Posted by chuck_eglin
(Post 61131)
Hi,
