Check Engine: Multiple Codes
Hi:
I have a 2009 C70 in which I recently replaced the engine with one from a 2008 C70 with fewer miles... (My '08 body was the loser in a car vs. deer incident, I bought an '09 with a blown engine)
The 2008 Engine has always been running well but occasionally threw a misfire code on a couple of cylinders.
Recently, the "Check Engine" light came on so I checked with a Bosch U-Scan OBDII code reader (Bluetooth to phone) and suddenly a whole host of codes are being thrown:
"Engine system service required"
A few questions:
First, and most important: Am I doing any damage to the car if I drive it before these are fixed?
I am hoping these are all related to a singular issue and that it is not too expensive a fix.
Does anyone have a suggestion as to what I should investigate first?
(P.S. I have a VIDA-DICE unit but it requires Windows 7 and IE9... IE Automatically updated to IE11 and now I can't get IE9 loaded again... so it's basically a brick, grrrr...)
Thanks!
- P0445: Evaporative Emissions System Purge Control Valve Shorted
- P0079: Exhaust Valve Control Solenoid Circuit Low (Bank 1)
- P0076: Intake Valve Control Solenoid Circuit Low (Bank 1)
- P0245: Turbo Wastegate A Solenoid Low
- P2419: Evaporative Emission System Switching Valve Control Circuit Low
- P2401: Evaporative Emission System Leak Detection Pump Control Circuit Low
- P0497: Evaporative Emission System Low Purge Flow
- P0102: Mass Or Volume Air Flow Circuit Low Input
A few questions:
Thanks!
Hi:
A few questions:
Thanks!
A few questions:
Thanks!
https://www.raramuridesign.com/kb/ar...lity-mode.html
Did you ever resolve all of those CEL codes. I am having the same ones except for P0497.
