Crankcase vacuum
Crankcase vacuum
I am having an issue with my 2011 c-70. It was squealing and building crankcase vacuum all the signs of a ruptured diaphragm in the pcv system. I replaced the oil filter module which has the diaphragm In it. However I still get the squealing and building vacuum in the crankcase however not as much as before.
a professional shop will use a vaccuum gauge to see if your crank case pressure is within spec. Normally the problem is when there's positive pressure (ie clogged PCV/ports which don't allow the intake to pull the vacuum). What happens when you pop up the dipstick? (to allow a vent) does the sound change?
