drivers door window
Hi i am new to this i have recently bought a 1998 c70 T5 GT 2.3 the drivers door window looks to stick out a bit when door is closed,When driving on motorway or at speed can hear the wind what could be causing this someone suggested moving the door clip in to see if it pulls further in but wont this make my door not flush as it is pulled in
thanks for any advice
I am assuming you have a coupe. Next time you are in the auto.........close the door and then lower the window an inch or so and then raise it. My old coupe does the same and I found that the top of the window is hanging up on the weather seal surrounding the door. Annoying but it works.
r.
r.
850GLTWAGON
11-21-2008 04:14 PM
