Engine is "bucking" upon deceleration...
Old Dec 15, 2008 | 04:33 PM
Colleyvilletiger's Avatar
Default Engine is "bucking" upon deceleration...
in my recently purchased 2002 C70. 1700 RPM is the sweet spot, let off the gas and it lurches and bucks. Dealer squared away the battery cables and one vacuum line, but discovered that the engine appears to have been changed, and they surmise it's an interfacing issue with the ECU and engine (?).ETM appears fine. Possibly a factor, the tires are suspect and are adding a degree of "out of round" or something; I shift to neutral to separate the two effects and am convinced it's not totally the tires. Ideas?
Old Dec 17, 2008 | 02:41 PM
TIPSP's Avatar
Got Boost?
Default RE: Engine is "bucking" upon deceleration...
Not sure on this. Maybe something with the transmission?
Wait and see what (Moderator) Tech says.
Old Dec 17, 2008 | 02:55 PM
Throttle body clean?
Good tune up?
Old Dec 18, 2008 | 03:04 PM
Yep, I was thinking it was ETM and had the Volvo dealer upgrade software, then clean the throttle body. It was then they discovered the liklihood of an engine changeout. Not sure about the tuneup and plugs, 98K miles on car, who knows on engine (it looks newer though). Sorry on double post, didn't look like anyone checked the C70 section, for obvious reasons
jayson44
Jun 19, 2016 12:16 PM
RPMCanes
Jul 26, 2012 09:36 AM
bengaltiger
Jan 23, 2011 12:48 AM
sparky bob
Oct 28, 2009 10:24 PM
axelm
Sep 11, 2007 11:17 PM
