falsher...
Old Mar 4, 2008 | 09:08 PM
c70turbogt's Avatar
Default falsher...
is the flasher relay the same for all of the cars ie 98,99,00
Old Mar 4, 2008 | 09:26 PM
Default RE: falsher...
should be.
Old Mar 13, 2008 | 04:05 PM
c70turbogt's Avatar
can someone please explain to me how to replace the flasher.....i hear its not as easy as an american car......
Old Mar 13, 2008 | 08:00 PM
I believe it is the hazard switch it should slide out.
Old Mar 13, 2008 | 10:11 PM
c70turbogt's Avatar
where does it slide out from?
Old Mar 14, 2008 | 06:55 PM
The hazard switch should slide straight out.
It might be easier to remove the radio and push it out.
Old Mar 17, 2008 | 05:21 PM
c70turbogt's Avatar
so the relay its self is in the hazard signal button?
Old Mar 17, 2008 | 07:55 PM
Yes it is. If the turn signals stop flashing try hitting the hazard switch a few times and see if they start working.
Old Mar 25, 2008 | 08:14 PM
c70turbogt's Avatar
Im back.....so right now my turn signals dont flash and my hazards dont flash. what your saying is the relay for all of it is in my hazard under the radio.....im talking the relay flasher not the hazard button mechanism.....(and i pressed the hazard on and off..... )
thanks for your patience
Old Mar 26, 2008 | 06:53 PM
Last I knew it was all in one.
