Front door speakers problem.
Old Jan 16, 2025 | 06:00 PM
Jimppa's Avatar
Default Front door speakers problem.
I Have 1999 Volvo C70, and i was normally driving when my lower door speakers just stopped working so where i could search the issue, Back basses Works normally and everything else, and i know that amp is in the trunk but i Have convertible so there is some mechanism of roof that is in the way so if there is anything else where this problem can Be i would Look it first.... Sorry very Bad english....
Old Jan 22, 2025 | 03:57 PM
Issue is either wiring or the amp. You may need to open up the dash to access the amp then run a test signal to see if the speakers work. If they are good then its time to check the amp.
Rob.euser
Jan 16, 2025 05:47 PM
Hokiefanatic93
Jul 22, 2011 11:06 PM
colgate41
Oct 23, 2008 09:10 AM
mjbdj
Jun 20, 2008 11:34 AM
ibmkillr
Nov 9, 2005 03:56 PM
