Headlights set too low
Old Sep 13, 2006 | 12:48 PM
casique's Avatar
Default Headlights set too low
I have searched through the forum and found a lot of info on the light adjustment topic. However, I wanted to know if anybody has the specifics on the 2006 C70 with halogens? Like pics of the bolts and which way to turn the bolt to adjust UP! Thanks.
Old Sep 13, 2006 | 08:27 PM
Default RE: Headlights set too low
Sorry haven't seen a 2006 yet not sure if they are the same as the old ones.
If it is a 2006 have the Dealer adjust them.
Old Sep 13, 2006 | 10:31 PM
casique's Avatar
Figured it out!
The 2006 C70 has two white adjustment 6mm bolts per side. The white nut closer to the top rear side of the light assembly adjusts the side to side, the one below and closer to the side of the vehicle adjusts the up and down. I must have turned the bolt about six or seven full turns to move the light 3 inches up. I'll check it out tomorrow morning and go from there.
It worked like a charm! Turn clock wise to lower the light, counter to raise the light.
Sir James
Nov 7, 2012 03:38 AM
VDriver24093
Feb 21, 2011 04:35 PM
elderzap
Nov 7, 2007 04:58 PM
ninnemand
Feb 17, 2006 12:45 AM
Eric
Jan 19, 2006 08:41 PM
