I want to lower my 99 C70. Spring info Needed
Old Nov 11, 2006 | 09:01 PM
davefromwilmington's Avatar
Default I want to lower my 99 C70. Spring info Needed
I want to lower my 99 C70. Spring info Needed. If anyone has tried some different ones and can give me some info it will be appreciated. Oh and im new to this forum so everyone that knows what they are doing here must be patient with me. Pics coming soon.
Old Nov 11, 2006 | 10:41 PM
S70driver's Avatar
Default RE: I want to lower my 99 C70. Spring info Needed
Ok.
Welcome
1. What is your budget?
2. How low are you looking to lower the car?
Options
1. Eibach Springs from EST
2. KW Coilovers from EST
3. Eibach Springs from IPD
4. Sport Springs by IPD
5.Eibach Springs from Viva Performance
6. H&R Springs from Viva Performance
7. KW Coilovers from Viva Performance
Old Nov 12, 2006 | 05:01 AM
The budget is $200-$300. I have about a 3" gap between my wheelwells and my tires. Im looking for a true 1.5" drop in the front and rear. I see that the springs generally drop your car 1" up to 2.5" however I have read in some webpages that some springs tend to drop your car much more than the manufacture says they will. Also can I safely and comfortably get away with not replacing the struts or will leaving the factory struts cause the awful jaw-breaking bounce that you sometimes get with some springs. thanks for your help!!!!!!!!!!!
Old Nov 12, 2006 | 11:40 AM
S70driver's Avatar
ORIGINAL: davefromwilmington
If you want to do things right you would get all new suspension parts when you do a suspension upgrade. But this is expsensive.
As you would want to do Springs, Shocks/Struts,Sway Bars, Etc...
However you should be fine with the stock shocks/struts. If you decide to upgrade them go with KONI's or Bilstein HD's.
Old Nov 12, 2006 | 04:55 PM
S70driver's Avatar
As far as your budget goes. I would go for the Sport Springs by IPD, Eibach's from IPD, H&R's from Viva Performance.
P.S.: Right now EST is having a sale on the Eibach springs at a really good price.
Old Nov 12, 2006 | 11:32 PM
I like eibach and have used them on many of my cars.
nortons
Feb 22, 2015 11:14 PM
nicolaselias
Mar 24, 2011 08:48 PM
AK
Suspension
Aug 22, 2006 02:03 PM
jmc00v70
Suspension
18
May 22, 2006 11:09 AM
Beau
Sep 15, 2004 02:40 AM
