manual boost??
Old May 8, 2007 | 08:52 AM
heresssjonny's Avatar
Default manual boost??
hey guys newbie here just got myself a c70 and love it its a 2001 2.0 lpt its got the common window whistling but im sure i can sort that. my q is can i use a manual boost controler on this as ive heard it can cause issues? or should i save for a ecu upgrade?? as it just isnt quite fast enough. thanks guys
Old May 8, 2007 | 12:23 PM
S70driver's Avatar
Default RE: manual boost??
Welcome to the forum.
No you cannot use a MBC. ME7 cars do not like MBC's at all. An ECU upgrade is the way to go if you want to raise your boost levels.
However I suggest doing a complete STAGE ZERO first, which can be found in the link provided in my signature. Also a boost gauge is warranted as well.
Old May 10, 2007 | 07:10 AM
cool thanks im glad i asked so is mine a me7?? also do you know if a dump valve will cause any probs if i gofor the ecu upgrade? are any dump valves better than others?? il post some pics soon. cheers j
Old May 10, 2007 | 08:09 AM
S70driver's Avatar
1. Yes you are ME7. Any Volvo 1999+ is ME7.
2. No a dump valve should not cause any problems ever. Other then running rich for a split second when it goes off. Also if your automatic you will only hear the sound when you let off the gas.
I suggest an HKS SSQV first a foremost, TIAL is very good as well.
thecheat
Sep 22, 2010 08:48 PM
turbo940v
Sep 3, 2010 08:36 AM
endneu913
Mar 28, 2010 11:41 PM
mygreenbomb
Feb 29, 2008 06:09 PM
blkwgnt5r
Mar 10, 2005 01:18 PM
