My C70
Old Aug 21, 2008 | 11:55 AM
ProlixArgon's Avatar
Default My C70
This is my first C70.
[IMG]local://upfiles/17930/FAAD770B14124478ADE85BC1F95BF879.jpg[/IMG]
[IMG]local://upfiles/17930/64FE705F4DA3435484C52494729E6A96.jpg[/IMG]
[IMG]local://upfiles/17930/DBD6FBD523FC4417B266B75783DB4B4C.jpg[/IMG]
She's a recovered theft vehicle. I looked her over and so far all I can see that she needs is a battery, spark plugs, front shocks, two timing belt pulleys, the right CV boot, a radio, and a lot of sanding and polishing on the exterior paint to deal with orange peal. She has a high pressure turbo and only 65,000 miles. I paid about $2100 for her.
Now I need to modify her so that she can out perform my 97 M3. This should be fun.
Old Aug 21, 2008 | 09:08 PM
Default RE: My C70
Looks really good I have a soft spot for a Black Coupe!!
Old Aug 22, 2008 | 03:19 AM
andry's Avatar
Default RE: My C70
nice looking ride, sporty style
anyway, welcome and enjoy your ride.
Old Aug 22, 2008 | 06:53 AM
Default RE: My C70
I have a lot of questions to ask about modding, but I'm going to finish doing my "research" on what people have said already on this forum before I do that.
Next mod: replace the grille.
Tech, I have a question for you: my C70 has a xenon conversion for the low beam headlights. Will I have to buy another kit for the high beams or can I use the current kit to run both high and low?
Old Aug 22, 2008 | 08:07 AM
Default RE: My C70
Unless someone came out with something else you will need to buy another kit. But on mine I only run it on low beams. I never use high beams.The low beams are bright enough.
Old Aug 22, 2008 | 08:46 AM
Default RE: My C70
I've only driven the car a little bit, but I did notice that it made little difference if I turned on the high beams. I'll have to replace the factory high beam bulb with a blue bulb or something though, the yellow beside the HID looks very off kilter.
Have you had any trouble getting your car inspected with the HID low beams? I was told that it would be a good idea to put in a blue high beam bulb to pass inspection.
Old Aug 22, 2008 | 11:52 AM
Default RE: My C70
Sorry but I don't have any inspection at all here in Florida.
securisign
May 31, 2014 11:10 AM
GoVolvoParts
Nov 29, 2012 08:46 AM
