no throttle responce after battery disconnected for 3 week
Old May 13, 2010 | 11:26 AM
james thomas's Avatar
Default no throttle responce after battery disconnected for 3 week
i have recently install a persons used engine is was a big problem the engine was the wrong year had to order a lot of parts to make everything fit right, but the throttle plate came with the car i went to start it up and it won't rev above 2100 rpm with the computer scaner was showing no throttle % is in limp home mode, or has it just lost comumication with the throttle plate, does it need to be relearned?
Old May 13, 2010 | 09:17 PM
Check the main ground wire going to the transmission.
Old May 14, 2010 | 08:24 AM
Default no throttle responce after battery unhook for 3 week
have checked all grounds and all connection
Old May 15, 2010 | 12:17 PM
Is the ground cable where it originally was?
Also check the crank sensor.
Old May 17, 2010 | 08:17 AM
Default Ground strap
The ground strap was never remove the engine was pulled with the transmission in place
Old May 17, 2010 | 10:49 AM
mkc70's Avatar
What year is the C? Besides the new engine, were the original electrical components kept? eg. TCM, ETM, etc...
Old May 17, 2010 | 12:56 PM
Default 2000 c70
The car is a 2000 c70 it cam in to my shop with timing belt jumped and bent valves customer opt to get a used engine for it. The engine came out of a 1999 v70. The engine came with out a turbo on it nor did it have a throttle plate. Have tranfered all sensor ,turbo, throttle plate, injector,coil from the engine that came with the car so there should be no confusing with the calibration, but still i have a problem. My computer scanner is still not pulling any code out of the cars computer even though i have the ets light on i am sure that it is in limp mode. How do you reset it
Old May 17, 2010 | 03:16 PM
mkc70's Avatar
Perhaps your customer has extremely bad luck and is experiencing the ETM/TPS failure coincidentally. Regardless it should register on your code scanner. Normally I just use my laptop, but was also under the impression a hard reset was disconnecting your battery and touching the terminals together. Keep us posted, but it is always good idea to double check the previous work done.
Old May 18, 2010 | 03:49 PM
Default Same problem
I reset it twice and still unstable idle limited throttle and then the ets light comes on
Old May 26, 2010 | 10:59 AM
Default Fixed
Found bad ground on brown wire in harness next to starter
pagragg@pacbell.net
2001-2013 model year XC70
Nov 20, 2012 02:37 PM
PeterLeonard
Feb 25, 2012 11:01 PM
edddiec
Feb 2, 2011 10:46 PM
KubilayK
Nov 24, 2008 07:57 AM
