Pillar Mounting System???
Old Feb 24, 2007 | 02:43 AM
01C70's Avatar
Default Pillar Mounting System???
Does anyone know where I could find a two or three pillar mounting system design for a 2001 C70?
Old Feb 24, 2007 | 11:38 AM
S70driver's Avatar
Default RE: Pillar Mounting System???
Are you talking about a double or triple gauge pod?
1. You need to search.
2. You need to go to, http://www.gaugepods.com
This is where you will buy the triple gauge pod from. Buy the one for the 70 series Volvo's.
3. Then you will send your triple gauge pod and stock A-pillar to, http://www.rodpods.net/
He will mold the triple gauge pod into the stock Apillar for a very custom very OEM look.
4. The only other solution is to use mounting cups and they just look crappy. The above will look so much better.
Old Feb 25, 2007 | 12:39 AM
ORIGINAL: S70driver
Did I read on the site right $200.00 to fit it on?
Old Feb 25, 2007 | 01:26 AM
S70driver's Avatar
ORIGINAL: tech
ORIGINAL: S70driver
Yes it is very pricey. However Rod custom molds the Lotek (GaugePods.com) triple or single gauge pod into the stock A-pillar. I mean it looks completely OEM like it was meant to be there. Very nice work, but pricey.
Old Feb 25, 2007 | 01:36 AM
01C70's Avatar
The peeler I want is a triple gauge pod. I want a boost, oil pressure , and air/fuel guage; do you think these are 3 good choices? Do I need a certain type of guage for my C70?
Old Feb 25, 2007 | 01:58 AM
S70driver's Avatar
Default RE: Thanks...
ORIGINAL: 01C70
Awsome you will love the Triple gauge pod from LOTEK. You can see mine in my Signature.
The boost gauge is the most critical gauge to have so you know what your boosting. Oil pressure is another good gauge to have. I have both of these in my car. Now with the A/F Ratio gauge. DO NOT get a Narrow Band 02 gauge. It is just a pretty light show. If your really serious about knowing what your A/F Ratios are you will want a Wideband 02 gauge.
Here is the difference
Narrowband:
http://www.egauges.com/vdo_ind.asp?T...mp;PN=ATM-5775
Wideband:
http://www.egauges.com/vdo_ind.asp?T...mp;PN=ATM-5778
Egauges.com is a great place to buy all your gauges from. Great prices. Oh for the oil pressure gauge your going to need an adapter piece it is, Adapter Bushing - 1/8 NPT female x M14 X 1.5 malewhich can also be found on http://www.egauges.com/
GoldenAngel
Oct 7, 2007 10:43 PM
kyvahe
Oct 3, 2005 11:37 PM
Ferguson
Sep 18, 2005 11:22 PM
Lichty17
Aug 4, 2005 04:24 AM
