Please Help! 2012 C70 cranks but won't start!
Old May 29, 2019 | 12:00 AM
Michelle Riipinen's Avatar
Default Please Help! 2012 C70 cranks but won't start!
My car cranks but won't fire and I've tried everything! It sounds like it's so close to starting but then it won't ...please advise!
Old May 29, 2019 | 09:54 AM
any symptoms leading up to the no start? any check engine light or fault codes? any smell of gas? A no start could be a fuel delivery issue or a sensor (ie crank position) but you'd need to run some tests to narrow down. The basic tests are to determine if you are getting fuel and if you are getting spark but you'll likely need a shop with the proper diagnostic tools to sort it out.
Old May 29, 2019 | 10:38 AM
We did a bunch of tests yesterday and for some reason, fuel injector is not getting signal to go...starter works, no fuel smell, sensors are good, might have to break down and go to dealership
volvoFETT
Jan 5, 2017 07:26 PM
robshotrods
Jul 23, 2009 07:18 PM
rob60
Jul 7, 2009 06:56 PM
goldie
Oct 27, 2007 07:16 PM
Volvorator
Sep 21, 2005 10:22 PM
