Scanner from Ebay
Old Oct 2, 2006 | 03:59 PM
skipper's Avatar
Default Scanner from Ebay
Hi All
I just received a code reader that I bought off of ebay. It seems to be pretty good. The problem is I tried it because my Check Engine light has been on since I changed the plugs, wires and rotor.
The code showed up as p0006. Fuel Shutoff Valve. A control circuit low. Does this mean anything to you guys. I know I will have to take it to the dealer but the closest one is 1.5 hrs away. I would feel better driving it there knowing I am not damaging it further.
Tks
John
Old Oct 3, 2006 | 09:04 PM
Default RE: Scanner from Ebay
That might mean either the Gas cap is loose or something like that.
If it is running ok Clear the code and see how long it takes to come back.
Old Oct 3, 2006 | 09:44 PM
skipper's Avatar
It doesn't seem 100%, once in a while(maybe twice a day) it will stall when I come to a stop. As well maybe once a day it will bsckfire through the carb.(I know it is fuel injected, I am from the old school and that is the only way I can describe it:-).
John
Old Oct 3, 2006 | 10:08 PM
Are you sure it is P0006?
I can't find info on it as of yet.
I will try to look tomorrow.
Old Oct 3, 2006 | 10:24 PM
skipper's Avatar
Yes the scanner said P0006 and the book says that it is Fuel Shutoff Valve. A control circuit low.
Tks for checking it out.
John
nunrgguy
Aug 5, 2007 09:34 PM
Volvo2001
Oct 24, 2006 10:12 PM
axelm
Feb 27, 2006 09:06 AM
tomservo
Dec 25, 2005 03:01 AM
JimKW
Aug 4, 2005 12:07 AM
