SRI - Volvo C70
This is somewhat of a general question but I'm placing it here since I have a C70. I just performed the general maintenance on the car and I can't figure out how to turn off the SRI (service reminder indicator). I thought I could do it with my code reader but that didn't work. Any suggestions other than disconnecting the battery?
By the way, it's a 2006 model.
I've done it to my C70 '08 and daughter's S40 07:
* The service reminder indicator lamp illuminates for 120 seconds when the ignition is first switched on * Insert key and turn Ignition Switch to position I * Press and hold in the reset button for the trip odometer * Turn the Ignition switch to position II (within 2 seconds) * Hold the reset button for the trip meter pressed in until the original trip counter value blinks and is redisplayed (For all vehicles 2003- a general yellow lamp will light when the reset button must be released.) * Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when resetting has succeeded * If the trip meter is already reset the reset button should be held in for a minimum of 10 seconds and a maximum of 14 seconds. * If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator (SRI) is not reset. |
