SRI - Volvo C70
Old May 25, 2012 | 06:15 PM
GTOruss's Avatar
Default SRI - Volvo C70
This is somewhat of a general question but I'm placing it here since I have a C70. I just performed the general maintenance on the car and I can't figure out how to turn off the SRI (service reminder indicator). I thought I could do it with my code reader but that didn't work. Any suggestions other than disconnecting the battery?
Old May 25, 2012 | 06:16 PM
GTOruss's Avatar
By the way, it's a 2006 model.
Old May 26, 2012 | 05:06 AM
irbrenda's Avatar
I've done it to my C70 '08 and daughter's S40 07:
* The service reminder indicator lamp illuminates for 120 seconds when the ignition is first switched on
* Insert key and turn Ignition Switch to position I
* Press and hold in the reset button for the trip odometer
* Turn the Ignition switch to position II (within 2 seconds)
* Hold the reset button for the trip meter pressed in until the original trip counter value blinks and is redisplayed
(For all vehicles 2003- a general yellow lamp will light when the reset button must be released.)
* Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when resetting has succeeded
* If the trip meter is already reset the reset button should be held in for a minimum of 10 seconds and a maximum of 14 seconds.
* If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator (SRI) is not reset.
securisign
May 31, 2014 11:10 AM
GoVolvoParts
Nov 29, 2012 08:46 AM
akb1274
Aug 22, 2011 12:01 PM
nick_sixx
Apr 8, 2010 09:36 AM
lancaster1
Dec 8, 2008 09:16 PM
