SRS AND SHIFTER KNOB REPLACEMENT
Recently replaced steering wheel on my C70, now have SRS light on continously. Anyone know how to reset light? Also does anyone know how to change shifter knob on C70? Replacing mine with wood. Thanks.
RE: SRS AND SHIFTER KNOB REPLACEMENT
Did you install the set screw for the SRS contact reel?
If you didn't then you might have broke it and need to replace it. The shift know turn the boot on the bottom of the knob to release it. Then pull really hard to remove the knob. Easiest to do from Neutral or drive. |
