SRS AND SHIFTER KNOB REPLACEMENT
Old May 15, 2007 | 07:46 PM
map1470's Avatar
Default SRS AND SHIFTER **** REPLACEMENT
Recently replaced steering wheel on my C70, now have SRS light on continously. Anyone know how to reset light? Also does anyone know how to change shifter **** on C70? Replacing mine with wood. Thanks.
Old May 18, 2007 | 05:34 PM
Default RE: SRS AND SHIFTER **** REPLACEMENT
Did you install the set screw for the SRS contact reel?
If you didn't then you might have broke it and need to replace it.
The shift know turn the boot on the bottom of the **** to release it.
Then pull really hard to remove the ****.
Easiest to do from Neutral or drive.
Old Jun 20, 2007 | 10:47 PM
C70's Avatar
C70
I had to stand directly over the shift **** to pull it lose (its extremely hard to release)and when it released i knocked the rear view mirror silly.
xDread92x
Jul 21, 2019 04:18 PM
AlanS
Aug 3, 2012 08:37 PM
mark850t
Sep 29, 2011 11:08 PM
scouttyboy
Jul 8, 2008 05:35 PM
bambam
Feb 15, 2006 04:42 PM
