Top down trunk dimensions
Old Jul 29, 2011 | 02:53 AM
paulinbna's Avatar
Default Top down trunk dimensions
I am looking to get a C70 and would like to know the actual dimensions of the trunk with the top down. All I could find online where the cubic feet dimensions.
I really appreciate this info.
Thanks
Paul
Old Jul 29, 2011 | 07:17 PM
JayP71's Avatar
I own one. I don't know the dimensions but you don't have a lot of cargo space. After all the stuff you normally keep in your trunk you'll have enough left over for a moderate grocery run.
Old Jul 29, 2011 | 11:17 PM
Cactuslegs's Avatar
He probably is wanting dimensions to plan a sub box. I dunno what they are for a convertible, but if you want I can measure the space in my coupe.
Old Jul 30, 2011 | 12:23 AM
paulinbna's Avatar
Thanks Cactus but I was looking for the dimension of the space under where the top sits when down.
Old Jul 30, 2011 | 10:44 AM
Cactuslegs's Avatar
That's what I figured. Check out what this guy did in his trunk. He'd probably know for sure what the dimensions are, maybe you could sign up on that site and PM him.
http://www.cardomain.com/ride/390145...convertible-2d
Old Aug 1, 2011 | 07:00 AM
dragonwingvolvoc70's Avatar
don't know exact dimension #'s but top down and top up is the same on the softtop model.since that is a solid metal piece. height wise though under the top area is just barely taller than a gallon of milk standing up if that helps any
Old Aug 21, 2011 | 10:00 AM
Washington's Avatar
Does anyone know or could inform the trunk dimensions in cm or inches, when the conversible cab is in ? I need to know the maximum bag size could be carried. Thanks a lot. Washington from Sorocaba Brazil
Old Aug 22, 2011 | 04:35 AM
JayP71's Avatar
At least for the soft top the dimensions do not change. The top is in a separate boot from the trunk. There is a pass through to the rear seats that the owner's manual lists as a golf bag storage helper.
Don't have an exact number, never measured the trunk of my car before.
Golvo
Nov 16, 2010 08:17 PM
pacificnw2011
Sep 5, 2010 07:42 PM
Gregg
May 13, 2010 09:02 AM
Bobec
Nov 7, 2009 06:59 PM
crunch5868
Jul 24, 2008 12:28 AM
