TURN OFF CK ENGINE LIGHT
Hey Volvo Peoples,
Can ya all tell me how to reset the ck engine light on a 01 c70? I would appreciate the help. THANKS:eek: |
RE: TURN OFF CK ENGINE LIGHT
either pull the ECU fuse or diconnect the batteryfor like 2 mins. if it comes back on you have a problem.
I would pull the fuse, unless you have the radio code. Then it doesn't matter, except it's easier to pull the fuse.
B |
raido code??? i had a scare with my ETM and i pulled the fuse for the tranny, ECM and the ETM, but the battery was left hooked up. i didn't have to input a radio code though.
is that hard to put in? |
It is easy, but you need it if you disconnect the battery.
It's a 4 digit code that you input into the radio using the 1-6 preset buttons. Somwtimes it's included in you car information booklet, or you can get it from a dealer. B |
damn, see i bought my C70 used, so i have to look in the stuff that came with the car to see if there is a code inside.
If not have the Volvo store look the code up.
