Ugh. Water leaking in through pass door.
Old Oct 1, 2006 | 09:41 PM
Shaun Oriold1's Avatar
Default Ugh. Water leaking in through pass door.
So, my 2000 c70 convertible appearently leaks. I've owned this car for 2 weeks, and a bit of water was coming in through the bottom of the pass. door. It almost looked like it was coming out of the speaker. Now the bottom fabric of the door is all wet as well.
Anyone know what do to?
Shaun.
Old Oct 1, 2006 | 10:13 PM
Default RE: Ugh. Water leaking in through pass door.
The drains in the bottom of the door might be clogged.
Or the regulator is missadjusted and water is leaking in from the window and running down the inside of the door.
Old Oct 2, 2006 | 01:48 PM
topdwn's Avatar
I have the same problem, but only occasionally. It sounds silly but I have found that my car ony leaks around the pass. door when I park with the nose of the car pointing down.
Old Oct 5, 2006 | 02:59 PM
ORIGINAL: topdwn
Yeah. I back into my drive, and it has my car pointed down slightly, and I think its the same. I live on a busy street, and backing out will take forever with traffic. I checked in my drainage holes ( I found two - one at front of the door, and one at the back) and neither seemed to have anyhing in them. I guess I'll have to take it to the dealer.....Double Ugh!
S.
Old Oct 5, 2006 | 11:56 PM
Look really close at where the window meets the body and see if the window looks out of place.
fathcoltged
2001-2013 model year XC70
Apr 30, 2015 07:10 AM
Jim-Mer
Feb 22, 2011 11:21 PM
ibified
Nov 8, 2010 10:31 AM
ibified
Jun 16, 2010 08:35 AM
Vivi
Jan 17, 2010 01:28 PM
