Visor and battery drain
Old Oct 5, 2007 | 11:17 AM
newtome's Avatar
Default Visor and battery drain
I searched the other posts about fixing a visor, and someone mentioned their battery going dead.....something about the broken visor wires draining the battery. Well, last night, when I put my drivers side visor down, it made a snapping noise, and now it sags. When I put it down, the light above the visor does not come on. The passenger visor works fine. Should I be concerned about battery drain, etc. The battery is brand new and I don't want any problems! Thanks!
Old Oct 6, 2007 | 08:57 AM
Default RE: Visor and battery drain
If the wires end up touching then it will turn the light on and drain the battery.
Old Oct 6, 2007 | 01:34 PM
reg's Avatar
reg
might it not also blow the fuse??
r.
Old Oct 6, 2007 | 04:52 PM
Possibly but it usually just keeps the light on and kills the battery.
Old Oct 22, 2007 | 11:20 PM
Volvocars's Avatar
Just remove the two 10mm screws holding the sun visors pivot arm and unplug the visor. No more battery drain. No it won't blow the fuse; its a switch to shut off the visor that is most likly causing the problem. If you close the mirrors plastic cover it should shut off.
ajahn
Jun 14, 2019 12:09 AM
jbarnes
Jun 12, 2013 11:46 AM
nelson76
Jun 14, 2011 01:53 PM
harebearva
Oct 24, 2008 11:15 AM
rvinson
Sep 22, 2006 09:07 PM
