Water Drainage Concern - 2009 C70
Old Aug 19, 2017 | 04:03 PM
jlferrellFL's Avatar
Default Water Drainage Concern - 2009 C70
Hello. I was removing my license plate light bulb assemblies. One bulb was burned out and the other was as dim as the sun, as seen from Pluto. The removal was a piece of cake!
However, as I began removing the first screw, water started dripping off the screw and once the screw was completely removed, a little stream started. The second screw did the same as I began to removed it, (two screws per assembly). The other light assembly responded the exact same way with water coming out of the two screw holes. If I would have been prepared and able to collect the water, there would have been over a pint.
I know this water should not be retained in the trunk lid. Has anyone encountered this with their Volvo? If so, what seemed to correct the problem? If not prior experience, any suggestions?
Thank you, Jack
Old Oct 5, 2017 | 03:08 AM
DanielOsterberg's Avatar
1. Drain all the water you can from the trunk
2. Have a hose and spray some water on specific parts where the trunk meets the 3rd roof section and the body. Try to locate it where it enters, most common places are in the intersection between 3rd roof-trunk and body. There is butyl there to keep it water tight but this may sometimes not be enough so you need to re-seal. The gasket that runs along the back of the 3rd roof shell can also be leaking, and also the seals around the trunklid.
Take care of this ASAP if you get water in the lower part of the trunk you might end up with a huge bill replacing the hydraulic pump for the roof. It is located just behind the rear seat and sits in a whell where it can easliy accumulate water and damage electrics.
Water leaks between the "fake lamps" the lamps that are not illuminated on the trunk is not that uncommon and also the spoiler that sits in between.
rspi
May 25, 2012 09:09 AM
paul1149
Nov 1, 2009 12:27 PM
ShaunJ
Jun 2, 2008 02:59 AM
EAS1
Dec 22, 2006 07:03 PM
Ahmed
Feb 12, 2006 02:10 PM
