where is the amp in a C70-99
If your other speakers make noise then it's the tweeters. Each channel of the amp runs a corner of the car, and the center channel is powered by the radio, green plug on back. Just was messing with a factory tweeter this afternoon. Each one is held in by 2 plastic push pins. The dash ones use your drivers license to pop off the grill, and a small screwdriver to push the center pin down, pull up and lift out. Back requires the interior removed to access rear deck tweeters. Replace with same speaker or modify the factory bracket with aftermarket ones. Use the factory passive crossover beneath each tweeter, only need a soldering iron to remove the speaker leads from the circuit board. Good luck.
STREETFIGHTER50
10-23-2009 10:07 PM
huzzsaba
04-02-2009 05:35 PM
