XC40 C40 Steering Wheel Vibration
Hi,
My Volvo c40 when i drive around 65 miles per hour when i accelerate the steering wheel has a vibration, the vibration feels like more than a phone vibration, less than a massage device vibration, Does anyone has this problem experience?
Could it be a speed limit warning of some kind? Doesn't sound like mechanical vibration, especially if it only happens when you try to accelerate past 65mph.
Is it similar to the vibration you get if lane departure warning is active and you drift across lanes?
Clutching at straws here - are you by any chance using the orange "care key"? If so, there may be a separate speed limit function in the profile settings. I've never tried it so no idea how it works and the Volvo documentation doesn't describe it very clearly, but perhaps it could exhibit that behavior? What happens if you keep accelerating beyond 65 mph?
I have the same issue. Dealership said "I don't feel anything". I think it's the motor mounts.
motor mounts would present with power - so if you lift off the gas, the vibrations would reduce. More likely it would be wheels or axles. Any recent experience hitting a large pot hole? A quick test would be to do a front/rear tire rotation to see if the vibration changes. As to axles, you can inspect for any torn boots. Final thought - invite the service manager to go for a ride with you so you can point out the vibration with both of you in the car.
good to know - that would move up motor mounts and axles (and drive shaft bearing if you have AWD) up on the list of suspects. One way to check motor mounts is to "power brake" the engine to see if there's any unusual or excessive motion. ie open the hood, and stand to the side to watch the engine. Have an assistant start the car, then with the brakes on full, drop in to Drive. (make sure the car is pointing away from a garage etc in case they let the car lurch). did is move with the initial drop into drive? Next, with the brakes on full, apply some gas to rev the engine. Does the engine roll or lift up? If yes, inspect the motor mount/torque rods where you saw the motion. This doesn't always give a direct clue but it is something you can do for free :-)
Hello,
I have a C40 with this issue. my dealership recognized the vibration so far we have rebalanced and aligned tires, replaced the front drive axels, and got a whole new front motor from Sweden and installed it. The issue persists. The car is drivable but I can't stand driving it as I'm a commuter and spend 2 hours a day driving. Volvo engineering is attempting to find a solution and I'm still waiting for an answer. Sad part is volvo says they all do this. The XC40 Recharge allegedly doesn't have this problem. Maybe we should have bought that one?
@Dnikolica - I'm sorry to hear about your ordeal. Depending on where you live, you may be eligible for a buy back under local "lemon laws". If they've made three unsuccessful repair attempts on this issue and/or the car has been out of service for an extended period of time, you may meet the requirements. If you'd like to get rid of the car, I think a call to an attorney may prove worthwhile.
Any Luck with this? My newly leased XC40 recharge has intolerable vibration and the dealership is trying to tell me that all the electric models vibrate, as if that somehow makes it OK.
Hello,
Volvo car Steering Wheel Vibration issue, Volvo can not and won't fix it.
I brought my Volvo C40 to a dealership for the vibration issue 5 times, and both the dealer mechanic and manager, as well as a Volvo engineer, have experienced and acknowledged the vibration issue I've been having. However, despite contacting Volvo about the issue, they have stopped replying to my emails, because they don't want to fix it.
I recommend every one have the same Steering Wheel Vibration issue file complaint on bbb.org and local Lemon Law (find the link below), each state lemon law is different.
Volvo Card bbb.org
https://www.bbb.org/us/nj/mahwah/pro...-0221-29002860
Lemon law:
https://en.wikipedia.org/wiki/Lemon_law
Volvo Card bbb.org
Lemon law:
So, here is the situation, I leased a 2023 XC40 Recharge on March 25th. At this point they still have the car and are trying to fix it. They say that Volvo engineering is involved and have given me a loaner to use until my car is fixed. At least everyone is on the same page that this is an issue. I'll let you know how it goes. It's now been about 2.5 weeks since I picked up the car. Good luck to you. Get Volvo Cars USA involved. Open a case number.
Volvo Card bbb.org
Lemon law:
Volvo Card bbb.org
Lemon law:
If it becomes necessary, you can initiate a lemon law buyback claim in many states once the vehicle has been out of service for a certain number of days even if there haven't technically been three repair attempts. Hopefully they can fix it and that won't be necessary.
I experienced the same...Just bought a brand new C40, and the vibration was noticeable immediately after taking it home, but only at highway speeds...around 75 mph to be exact. I also noticed that the rear view mirror image was blurry, meaning the vibration traveled beyond the wheel and blurred the mirror. Like yours, the vibration was very high frequency, almost like an electric buzz, but definitely noticeable in the wheel. Finally, I had a mechanic from Volvo drive the car with me and he said he definitely felt it and that it "wasn't normal." Wheels, tires, rotors were all brand new and checked to be fine. Volvo got back to the service team and said that they have a "problem" with this issue and are still looking for a resolution...no fix in sight yet. It also happened on a few XC40 recharge models as well.
