TCAM Issues and Update
Hi. After a complete failure of the TCAM last month, I’m advised by Volvo corporate that an update is coming. The TCAM is the shark-fin shaped communication module on the roof and when it fails, as mine did, all communications, navigation and connectivity are lost. My local service facility did a reboot and reloaded what they say is an updates software; however they have advised me not to do the 2.2 software update as it will cause the TCAM software to revert to the original and fail again. Volvo has confirmed that a TCAM software update, separate from the upcoming version 2.2, is pending. Anyone else having TCAM issues?
Originally Posted by Mike and DeSha
(Post 514564)
(Post 514564)
We have an appointment with our local service facility in about a month, where it is fully expected that they will have to order a new part. Interesting to hear of this new update. |
Seems like i have the same issue and my XC40 Recharge was dead in the water and couldn’t even be unlocked as it lost connection to the keys also.
Finally got it started and then took it to Volvo as you can’t lock/unlock the car and nothing else that communicates with the car works either. We will see what they do to fix it and if this is a hardware or SW issue. |
I'm monitoring this because of owning a 2022 XC60 T8 ER, which is well known to also have TCAM problems. I've not had any such problems in 2 months and 2000 miles of ownership, but I'm anxious about it possibly happening, given how so many 2022 Volvo owners (amongst all models with the Google OS) have experienced the dead 12-volt battery and presumed TCAM issues. I suspect that some major software changes are needed to keep the 12-volt battery from dying (as they had to do with the Taycan), and that the TCAM issue is more software than hardware problems.
Car is back and it seems it was all software related. Volvo think it was an over air update that lost connection or somehow became corrupted (I like out in the countryside).
They reloaded the OS and we have turned off the auto-updates to stop any further updates for the time being. will see if this lasts and hope this helps. |
it seems to have TCAm problems with XC40 full electric
in my case, the car lost gps signal and could not find wifi signals. It presented alerts from the SOS system, it did not recognize the keys and at this moment it is in the service facility awaiting replacement of the TCAM module. Hopefully this resolves the situation.
Latest software has not fixed the SOS key fob problem
Same problem today on my x60 recharge late 2022.
Serviced a week ago. Had latest OTA 2.3 software update, didn’t get the issue until after the update. Did have issues with app not syncing since service. Removed fuse 39 and battery terminal for a few minutes, still not recognising both keys. Placed keys in cup holder and was able to start once and then after turning off, it wouldn’t start again. Going to service centre Monday to fix the priblem. |
