-   Volvo S40 (https://volvoforums.com/forum/volvo-s40-11/)
-   -   '00 S40 - Can bad coolant temp sensor actually prevent starting? (https://volvoforums.com/forum/volvo-s40-11/00-s40-can-bad-coolant-temp-sensor-actually-prevent-starting-71252/)
stevetro1 May 29, 2013 08:36 AM
Hi all,
You can browse my longer more detailed post on my issue here:
https://volvoforums.com/forum/volvo-...g-steps-71242/
But I was wondering if a faulty coolant temp sensor could actually prevent the car from starting? I ask this because I noticed when I attempted to start the car cold again this morning to no avail, the fans kick right on as soon as I turn the key off. The started turned maybe 4-5 times. After the fan shutoff I just turned the key on and off, no starter attempt, and the fan went right back on.
Seems strange, and I have been having odd temperature issues.
Hudini Jun 4, 2013 09:24 AM
I have heard of a faulty MAF causing the fans to run when they should not. No clue why the MAF would cause this.
m_chewan Aug 5, 2014 01:00 PM
Any solution yet?
Im having similar problems with erratic hard starting and fan coming on when cold. Did you replace the coolent sensor and did it solve your problem?
