'01 S40 need blowout valve?
Old Aug 17, 2008 | 12:12 PM
rd929's Avatar
Default '01 S40 need blowout valve?
I'm no car expert, but does an '01 S40 need a blowout valve? I am picking one up and I test drove it, but didn't hear a blowout valve from the 1.9.
I'm not looking for performance out of my Volvo, I just wanted to know if Volvo already took the precaution to think about the durability of the turbo
Old Aug 17, 2008 | 01:44 PM
S70driver's Avatar
Default RE: '01 S40 need blowout valve?
1. It is BLOW OFF VALVE (BOV).
2. You don't have one stock, you have a CBV.
3. You do not need one period. The CBV does the same job as a BOV. Just in a different way.
4. It wont do anything for your Volvo other then produce sound.
Old Aug 17, 2008 | 01:45 PM
S70driver's Avatar
"A compressor bypass valve (CBV), also known as a compressor relief valve or diverter valve, is a vacuum-actuated valve designed to release pressure in the intake system of a turbocharged or centrifugally supercharged car when the throttle is lifted or closed. This air pressure is re-circulated back into the non-pressurized end of the intake (before the turbo) but after the mass airflow sensor."
rhayles
Oct 24, 2012 11:02 AM
Rakam
May 27, 2011 09:03 PM
chachouu
Apr 8, 2010 03:51 PM
mygreenbomb
Feb 29, 2008 06:09 PM
