'03 S40 brake shudder
Old Jul 2, 2008 | 09:15 AM
casualfc's Avatar
Default '03 S40 brake shudder
'03 s40, 55k.
A few months ago I had front and back brakes replaced, pads, rotors. Was in a hurry so I paid the high cost at Midas.
When I'm going at a decent speed (over 30 mph? or so), I feel the front wheels (and the steering wheel) shudder. Stopping power is fine. This is just annoying. It's almost like the ABS is overdoing it.
As always, I would prefer to fix it myself instead of throwing out hundreds to a mechanic. Any suggestions?
Old Jul 2, 2008 | 10:04 AM
Eric J's Avatar
Default RE: '03 S40 brake shudder
Check your lug nuts first, they may have loosened. There is also the possibility the calipers nuts have loosened. After, if every thing is tight, a rotor may have warped. Midas may be goodat mufflers..................?
Bring it back to them. They should make good on the brake job.
Old Jul 3, 2008 | 09:48 AM
mcguij1's Avatar
also check to make sure they did actually change your rotors..if your rotors arent replaced they're probably warped and that can cause shuddering..
Old Jul 6, 2008 | 10:29 PM
casualfc's Avatar
Took it back to Midas. They replaced the rotors in Dec.
This time they mentioned that there was a good deal of rust on them so they surfaced and seem to be working fine now.
Old Jul 11, 2008 | 12:53 PM
chimmychong's Avatar
Volvo says rotors souldnt be resurfaced.........
also you could have not breakin the breaks in .......
plus causing warped rotors
TonyS
Sep 21, 2011 10:32 PM
NFrank89
Aug 26, 2011 07:53 PM
30KS80
Apr 13, 2005 05:26 PM
valerie
Aug 26, 2004 06:13 PM
dako
Nov 10, 2003 01:49 PM
