03 S40 Wineing Noise @ Start Up?
Old Apr 13, 2018 | 01:25 PM
cooperallie's Avatar
Question 03 S40 Wineing Noise @ Start Up?
When I start my S40 I hear a winning noise and the car seems to idle high. It resolves itself to normal after a short warm up. What I'm I dealing with?
Jim
Old Apr 14, 2018 | 06:02 PM
Vackers40's Avatar
Sounds like the pcv system maybe clogged.
Old Apr 15, 2018 | 09:59 AM
a quick test for the PCV would be to pull the dipstick out and see if the noise changes
Old Apr 17, 2018 | 05:40 PM
Hudini's Avatar
Is this something new? All S40s will idle high on a cold start. Then after a bit will idle down.
Whining could be anything from low power steering fluid to alternator bearings. If it's a continuous noise then you can find it with a mechanics stethoscope. The poor mans alternative is a rubber hose held to your ear while you move the other end around the engine compartment listening for the noise. The older S40s don't suffer the whistling of the newer 2004.5+ models from a clogged PCV system. They will push oil out of worn seals though.
George4
Sep 17, 2016 04:34 AM
Heather202
Apr 25, 2016 08:54 PM
Billybobcars
Sep 12, 2013 03:55 PM
chimmychong
Apr 2, 2008 08:39 AM
ludeless
Aug 28, 2007 07:14 PM
