07 s40 vibration solved
Old Nov 9, 2020 | 07:19 AM
chefusa's Avatar
Default 07 s40 vibration solved
after replacing CV joints front shocks wheel balancing front and alignment I finally discovered where the vibration originated. It appears that the right front motor mount had collapsed. After taking it to a mechanic it seems he overlooked that. Finally I discovered that collapsed right front shock Ordered it online for $33 it took approximately 45 minutes to install. This procedure is relatively simple, there are only four bolts that hold the right front engine mount in place. I jacked The motor up a couple of inches to take the pressure off the.old mount. after the installation was complete I test drove the car zero I repeat zero vibration when accelerating although it was minimal it annoyed me and now it is fixed. You can find instructions on YouTube if you need assistance. Cheers Chef Mario
Old Nov 10, 2020 | 04:34 AM
Hudini's Avatar
You mean this mount?
swedes
Feb 16, 2014 04:16 PM
buckhr
Apr 24, 2013 05:03 AM
Bigflynn33
Mar 16, 2012 08:50 AM
Meglog
Aug 17, 2006 09:17 PM
ClarkeRussell
Nov 22, 2005 12:45 AM
