2000 s40 Engine revs and accelerating
My 2000 S40 starting revving/accelerating without using the gas pedal. Had to keep the brake firmly down to keep from going through a stop sign.
What would cause this? It scared my wife, where she will not even ride in the car.
Any ideas?
thanks,
Any ideas?
thanks,
I would firstly check the throtle wire for any broken branches and after that I would check the throtle sensor for any dirty contacts or similar electrical mulfunction. I know the solution sounds simple for such a serious problem but I guess it is better to start from the simple staff. Good luck
Did you replace your spark plugs recently? I had the same accelerating problem. Reading through these forums, and reading the topic 'spark plugs' everyone recommended copper core spark plugs. i was sold Champion Double Platinum plugs at the store originally and then when i switched to NGK copper core plugs the problem went away.
Volvobirdie
1998-2000 model year V70
Sep 20, 2013 08:21 PM
Stephen Backway
Mar 1, 2013 04:08 PM
Bodders
Feb 8, 2009 08:15 PM
markjenross
Nov 7, 2007 08:02 PM
