2000 S40 hard shifting
Old Jun 14, 2016 | 09:33 PM
YungArtyV's Avatar
Default 2000 S40 hard shifting
Hi,
So my 2000 S40 with what I believe to be the AW50-42le, has shifting problems. Firstly I have the flashing arrow of failure. It came on a few months ago, apparently I was very low on fluid and had been for a while, which made sense as it was shifting strangely. I filled it up and after a few days the arrow went away and my transmission felt great. Now it's come back on, immediately when it came on, my volvo is leaking a ton of fluid through the output shaft seals and 2-3 shifts are very harsh. It seems to hold onto 2nd for too long and lets go harshly. 1-2 and 3-4 aren't good either. So my plan is to repair the seals as well as replace axles and struts. Will my transmission be ok or is there something I can replace to fix this? I don't want to do this big job just to have this transmission **** the bed in 3 weeks. Please help
Old Jun 15, 2016 | 09:17 AM
pierremcalpine's Avatar
based on the fact that your shifting was great when you topped up, I'm optimistic that fixing the leaks might address your issues - that is, assuming that you didn't drive major miles after the shifting went wonky. I would be tempted to hold off on the strut work until you can confirm that all is well though. Why are you replacing the axles? I would suggest simply replacing the two seals and see how you make out...unless of course the axles are confirmed as bad.
Old Jun 15, 2016 | 10:59 AM
YungArtyV's Avatar
Axles are indeed bad as well as my left strut (blown shock). I have been driving a while with the light on but rough shifting has only come back quite recently. I know this is irresponsible but I am a broke college student if that excuses me from ridicule. The fluid does not look or smell burnt. However I think I may have overfilled; can that give me these symptoms as well? Thanks so much for your advice.
Old Jun 15, 2016 | 12:17 PM
Got it. For what it's worth, I picked up two axles from the wreckyard for mine at a reasonable fee and they have done the job fine - smooth as silk 18 months in. Arguably better than going for new aftermarket as far as I'm concerned! On a related note - you could probably pick up two fully built struts from a junkyard as well if you are looking to save some bucks.
Not sure about the symptoms of overfilling. A quick google search suggests that it could lead to bad shifting. When you check your fluid level next time around - make sure you drive for 10min first. Ideally the fluid needs to be within a range of temps for the level check to work...just can't remember the exact temp. I think 10min of driving would do it. Good luck.
channel27
Sep 23, 2010 03:11 PM
Purplehaze799
Sep 15, 2008 10:42 PM
slickpartner
May 10, 2007 11:51 AM
stoya2s
Jan 17, 2006 09:18 PM
my850turbo
Dec 19, 2005 09:19 PM
