2000 S40 No Overdrive
Old Oct 3, 2014 | 10:29 AM
cdv's Avatar
cdv
Default 2000 S40 No Overdrive
I bought a 2000 S40, which now has 135,000 miles. I pulled code TCM-0054 with no description, and can't get any OBD codes off of it for the trans. After some research I found that the code description is "Lock-up pressure switch". I cleared the code, and had O/D once, then never again on the 15 minute freeway drive home. Only dropped out of O/D because I stopped to turn on to the freeway. Has anybody else had this problem? I'm really hoping the trans doesn't need to come out. I already have almost as much as I bought the car for dumped into repairs.
Old Oct 3, 2014 | 07:52 PM
Hudini's Avatar
Sounds like you need to replace the switch. I'd bet money it can be repaired in the car.
aryanvahedi
Oct 8, 2014 02:26 PM
lilsilver85
Aug 29, 2014 04:07 AM
S-40
Oct 15, 2013 05:32 PM
Helder
Mar 9, 2009 09:24 AM
master_pre
Sep 29, 2006 12:59 PM
