2000 s40 overheating?
Old May 2, 2008 | 12:29 PM
kroe's Avatar
Default 2000 s40 overheating?
I'll start at the beginning
4 or 5 days ago the check engine light comes on
stays on
Thursday Im driving the car everything seems fine (check engine light still on)
stop to get gas -5 minutes- start car - drive 2 blocks- temp gauge shoots up to red
stop car - put key in "run" position - 2 minutes - needle drops rapidly to halfway point
(not gradually but rapidly)
continue down the road with no problems
somewhere right in here the check engine light goes off
1 hour later stop again -30 minutes- start car and go to back out of slot and needle jumps to red - stop car and put key in run position again - 30 seconds - needle drops to halfway point (rapidly) (check engine light back on, and stays on)
1 hour later same scenario
90 minutes later I get home and park car
let car sit for one hour and check coolant - coolant level good
start car and after about 3 minutes needle jumps to red
once again I turn the car off and place key in run position and 2 minutes later needle returns to halfway point
Now, could it be the thermostat or sensor or what?
(Mileage - 107,500)
Old May 3, 2008 | 05:42 PM
johntua1's Avatar
Default RE: 2000 s40 overheating?
Could be one or both of those. Get to autozone and have them read the codes on the computer (for free). If it shows thermo is bad, just grab one and replace it. The temp sensor might also show, but since it's fairly expensive, I would just erase the codes, replace thermo, and see if that fixes it.
trade in my volvo
Mar 13, 2015 05:35 PM
EisenhardtS80
Dec 20, 2013 11:04 PM
uwphoto48
Dec 23, 2012 02:51 PM
brownbeltmama
May 26, 2011 12:55 PM
stella
Aug 5, 2009 09:33 PM
