overheating 2000 s80T
Old Oct 30, 2014 | 01:23 PM
trade in my volvo's Avatar
Smile overheating 2000 s80T
Have a 2000 s80T, overheating- coolant tank bubbles after60 seconds run.
replaced fan assembly ( with module) same thing.
tested voltage at fan connector- 12 volts both sides in and out. tested black and white wires right at fan- no power.
where is coolant temp sensor located?
hoe this is an easy fix, need to get emissions asap.
would like to find a manual also. cant seem to find a Chilton that covers this year and model.
also where can I buy a code reader for this car. went to O'rielly auto parts. they said their obd1 and 11 will read it. called mfg and said no. sure would like a brand that someone is using.
Thank you guys so much
Last edited by trade in my volvo; Oct 30, 2014 at 01:26 PM. Reason: forgot something
Old Mar 8, 2015 | 07:47 PM
xtoor's Avatar
odb2 is what u need i have same car, you can buy a cheap one at walmart, as for the fix i have no clue my issue is also with the coolant but different issue i have to fill it up evey morning is leaking by the left corner of radiator
Old Mar 13, 2015 | 05:35 PM
difflock54's Avatar
Bubbling in the coolant reservoir is quite possibly caused by a leaking head gasket.
Get a compression check or a leak down test done asap.
Is any coolant being lost from the system, maybe via the exhaust?
The coolant can be tested for traces of exhaust gases which would also confirm a head gasket problem.
phils94850
Dec 17, 2009 03:25 AM
phils94850
Dec 16, 2009 03:23 PM
frankgh
Jul 4, 2009 07:58 PM
jstgermain
Sep 4, 2007 08:48 PM
robretpd
Feb 18, 2006 09:55 PM
