2000 S40 Timing Belt Identification
Old Jun 21, 2017 | 11:00 AM
chadwick_90's Avatar
Default 2000 S40 Timing Belt Identification
Hi, new to the forum. Have already learned so much from searching through this forum however I have one question regarding the stock/original timing belt/idler/tensioner.
I recently purchased a 2000 Volvo S40 1.9T with 111,000 miles . Kind of took a gamble since it did not come with any service history. I had some work done to it a week ago I had originally made the appointment to have the timing belt and all the other components that go with it changed since I wasn't sure if it had been done. Long story short the mechanic (indy not dealer) told me belt looked like it for sure has been changed before.. does anyone recall what the original belt/idler wheel looks like on this car? the belt does not look like it would have 111,000 miles on it but i know looks can be deceiving.
Old Jun 21, 2017 | 09:37 PM
tough to answer since the service interval is 100K miles or 10 years - just about every gen 1 S40 should have had at least one timing belt change. the maintenance calls for replacing the belt and tensioner and you should inspect the serpentine belt as well since you don't want that to fail and take out the timing belt. Does the belt show genuine Volvo branding or aftermarket (ie Conti is what I used)?
Old Jun 23, 2017 | 08:32 PM
Hudini's Avatar
Old Jun 26, 2017 | 04:48 PM
thank you, I'm going to pull the cover off this weekend to look at it. Do I have to remove the motor mount and move stuff out of the way just to check the lower half of the timing belt components ( water pump, tensioner)? And also, is there any warning to a idler or tensioner failing or is it an instant failure?
Old Jun 26, 2017 | 05:10 PM
henrysin44
Jul 20, 2015 09:12 PM
utapesgeometriam
May 22, 2015 12:55 PM
cljimmy72
Dec 15, 2014 04:24 AM
cartesianlogic
Nov 22, 2014 07:44 AM
2001S40nj
Nov 20, 2013 12:52 PM
